Dimis
Amazing , and the video is extremely helpful.UPDATE : I found the perfect match!!!!
Ersatz für Ferron 522 30-450N - Gasfedershop.ch
The piston and hub diameter are a bit larger than the original piece, but it has 0 influence on the result. What's important is the length of the piece and this one his 184mm long. Exactly like the original one.
Ps: the G4 12 80 worked also very good for me, but I still considered it an half-fix bcs I couldn't screw the second bolt (like I showed in the video)
Ich habe das gleiche Problem und lebe auch in der Schweiz.
Just ordered the piece in 30N
I will try to post the results here.
Danke
